CMA-ES stochastic optimizer class with ask-and-tell interface.
Calling Sequences
  • es = CMAEvolutionStrategy(x0, sigma0)
  • es = CMAEvolutionStrategy(x0, sigma0, opts)
  • es = CMAEvolutionStrategy(x0, sigma0).optimize(objective_fct)
  • res = CMAEvolutionStrategy(x0, sigma0,
                            opts).optimize(objective_fct).result
Arguments
x0
initial solution, starting point. x0 is given as "phenotype" which means, if:
opts = {'transformation': [transform, inverse]}
is given and inverse is None, the initial mean is not consistent with x0 in that transform(mean) does not equal to x0 unless transform(mean) equals mean.
sigma0
initial standard deviation. The problem variables should have been scaled, such that a single standard deviation on all variables is useful and the optimum is expected to lie within about x0 +- 3*sigma0. See also options scaling_of_variables. Often one wants to check for solutions close to the initial point. This allows, for example, for an easier check of consistency of the objective function and its interfacing with the optimizer. In this case, a much smaller sigma0 is advisable.
opts
options, a dictionary with optional settings, see class CMAOptions.
Main interface / usage
The interface is inherited from the generic OOOptimizer class (see also there). An object instance is generated from:
es = cma.CMAEvolutionStrategy(8 * [0.5], 0.2)
The least verbose interface is via the optimize method:
es.optimize(objective_func)
res = es.result
More verbosely, the optimization is done using the methods stop, ask, and tell:
while not es.stop():
    solutions = es.ask()
    es.tell(solutions, [cma.ff.rosen(s) for s in solutions])
    es.disp()
es.result_pretty()
where ask delivers new candidate solutions and tell updates the optim instance by passing the respective function values (the objective function cma.ff.rosen can be replaced by any properly defined objective function, see cma.ff for more examples).
To change an option, for example a termination condition to continue the optimization, call:
es.opts.set({'tolfacupx': 1e4})
The class CMAEvolutionStrategy also provides:
(solutions, func_values) = es.ask_and_eval(objective_func)
and an entire optimization can also be written like:
    es.tell(*es.ask_and_eval(objective_func))
Besides for termination criteria, in CMA-ES only the ranks of the func_values are relevant.
Attributes and Properties
  • inputargs: passed input arguments
  • inopts: passed options
  • opts: actually used options, some of them can be changed any time via opts.set, see class CMAOptions
  • popsize: population size lambda, number of candidate solutions returned by ask ()
  • logger: a CMADataLogger instance utilized by optimize
Examples
Super-short example, with output shown:
>>> import cma
>>> # construct an object instance in 4-D, sigma0=1:
>>> es = cma.CMAEvolutionStrategy(4 * [1], 1, {'seed':234})
...      # doctest: +ELLIPSIS
(4_w,8)-aCMA-ES (mu_w=2.6,w_1=52%) in dimension 4 (seed=234...)
and optimize the ellipsoid function
>>> es.optimize(cma.ff.elli, verb_disp=1)  # doctest: +ELLIPSIS
Iterat #Fevals   function value  axis ratio  sigma  min&max std  t[m:s]
    1      8 2.09...
>>> assert len(es.result) == 8
>>> assert es.result[1] < 1e-9
The optimization loop can also be written explicitly:
>>> es = cma.CMAEvolutionStrategy(4 * [1], 1)  # doctest: +ELLIPSIS
(4_w,8)-aCMA-ES (mu_w=2.6,w_1=52%) in dimension 4 (seed=...
...    X = es.ask()
...    es.tell(X, [cma.ff.elli(x) for x in X])
...    es.disp()  # doctest: +ELLIPSIS
    1      8 ...
achieving the same result as above.
An example with lower bounds (at zero) and handling infeasible solutions:
>>> import numpy as np
>>> es = cma.CMAEvolutionStrategy(10 * [0.2], 0.5,
...         {'bounds': [0, np.inf]})  #doctest: +ELLIPSIS
(5_w,...
...     fit, X = [], []
...     while len(X) < es.popsize:
...         curr_fit = None
...         while curr_fit in (None, np.NaN):
...             x = es.ask(1)[0]
...             curr_fit = cma.ff.somenan(x, cma.ff.elli) # might return np.NaN
...         X.append(x)
...         fit.append(curr_fit)
...     es.tell(X, fit)
...     es.logger.add()
...     es.disp()  #doctest: +ELLIPSIS
Itera...
>>> assert es.result[2] < 9000  # by internal termination
>>> # es.logger.plot()  # will plot data
>>> # cma.s.figshow()  # display plot window
An example with user-defined transformation, in this case to realize a lower bound of 2.
>>> import warnings
>>> with warnings.catch_warnings(record=True) as warns:
...     es = cma.CMAEvolutionStrategy(5 * [3], 0.1,
...                 {"transformation": [lambda x: x**2+1.2, None],
...                  "verbose": -2,})
>>> warns[0].message  # doctest:+ELLIPSIS
UserWarning('in class GenoPheno: user defined transformations have not been tested thoroughly ()'...
>>> warns[1].message  # doctest:+ELLIPSIS
UserWarning('computed initial point...
>>> es.optimize(cma.ff.rosen, verb_disp=0)  #doctest: +ELLIPSIS
<cma...
>>> assert cma.ff.rosen(es.result[0]) < 1e-7 + 5.54781521192
>>> assert es.result[2] < 3300
The inverse transformation is (only) necessary if the BoundPenalty boundary handler is used at the same time.
The CMAEvolutionStrategy class also provides a default logger (cave: files are overwritten when the logger is used with the same filename prefix):
>>> es = cma.CMAEvolutionStrategy(4 * [0.2], 0.5, {'verb_disp': 0})
>>> es.logger.disp_header()  # annotate the print of disp
Iterat Nfevals  function value    axis ratio maxstd  minstd
...     X = es.ask()
...     es.tell(X, [cma.ff.sphere(x) for x in X])
...     es.logger.add()  # log current iteration
...     es.logger.disp([-1])  # display info for last iteration   #doctest: +ELLIPSIS
    1  ...
>>> # es.logger.plot() # will make a plot
Example implementing restarts with increasing popsize (IPOP):
>>> bestever = cma.optimization_tools.BestSolution()
>>> for lam in 10 * 2**np.arange(8):  # 10, 20, 40, 80, ..., 10 * 2**7
...     es = cma.CMAEvolutionStrategy('6 - 8 * np.random.rand(9)',  # 9-D
...                                   5,  # initial std sigma0
...                                   {'popsize': lam,  # options
...                                    'verb_append': bestever.evalsall})
...     logger = cma.CMADataLogger().register(es, append=bestever.evalsall)
...     while not es.stop():
...         X = es.ask()    # get list of new solutions
...         fit = [cma.ff.rastrigin(x) for x in X]  # evaluate each solution
...         es.tell(X, fit) # besides for termination only the ranking in fit is used
...         # display some output
...         logger.add()  # add a "data point" to the log, writing in files
...         es.disp()  # uses option verb_disp with default 100
...     print('termination:', es.stop())
...     cma.s.pprint(es.best.__dict__)
...     bestever.update(es.best)
...     # show a plot
...     # logger.plot();
...     if bestever.f < 1e-8:  # global optimum was hit
...         break  #doctest: +ELLIPSIS
(5_w,...
>>> assert es.result[1] < 1e-8
On the Rastrigin function, usually after five restarts the global optimum is located.
Using the multiprocessing module, we can evaluate the function in parallel with a simple modification of the example (however multiprocessing seems not always reliable):
>>> from cma.fitness_functions import elli  # cannot be an instance method
>>> from cma.fitness_transformations import EvalParallel
>>> es = cma.CMAEvolutionStrategy(22 * [0.0], 1.0, {'maxiter':10})  # doctest:+ELLIPSIS
(6_w,13)-aCMA-ES (mu_w=...
>>> with EvalParallel(es.popsize + 1) as eval_all:
...         X = es.ask()
...         es.tell(X, eval_all(elli, X))
...         es.disp()
...         # es.logger.add()  # doctest:+ELLIPSIS
Iterat...
The final example shows how to resume:
>>> import pickle
>>> es = cma.CMAEvolutionStrategy(12 * [0.1],  # a new instance, 12-D
...                               0.12)         # initial std sigma0
...   #doctest: +ELLIPSIS
(5_w,...
>>> es.optimize(cma.ff.rosen, iterations=100)  #doctest: +ELLIPSIS
I...
>>> pickle.dump(es, open('_saved-cma-object.pkl', 'wb'))
>>> del es  # let's start fresh
>>> es = pickle.load(open('_saved-cma-object.pkl', 'rb'))
>>> # resuming
>>> es.optimize(cma.ff.rosen, verb_disp=200)  #doctest: +ELLIPSIS
  200 ...
>>> assert es.result[2] < 15000
>>> assert cma.s.Mh.vequals_approximately(es.result[0], 12 * [1], 1e-5)
The following two enhancements are implemented, the latter is turned on by default for very small population size only.
Active CMA is implemented with option CMA_active and conducts an update of the covariance matrix with negative weights. The negative update is implemented, such that positive definiteness is guarantied. A typical speed up factor (number of f-evaluations) is between 1.1 and two.
References: Jastrebski and Arnold, Improving evolution strategies through active covariance matrix adaptation, CEC 2006. Hansen, The CMA evolution strategy: a tutorial, arXiv 2016.
Selective mirroring is implemented with option CMA_mirrors in the method get_mirror and get_selective_mirrors. The method ask_and_eval (used by fmin) will then sample selectively mirrored vectors within the iteration (CMA_mirrormethod==1). Otherwise, or if CMA_mirromethod==2, selective mirrors are injected for the next iteration. In selective mirroring, only the worst solutions are mirrored. With the default small number of mirrors, pairwise selection (where at most one of the two mirrors contribute to the update of the distribution mean) is implicitly guarantied under selective mirroring and therefore not explicitly implemented.
References: Brockhoff et al, PPSN 2010, Auger et al, GECCO 2011.
See Alsofmin (), OOOptimizer, CMAOptions, plot (), ask (), tell (), ask_and_eval ()
Method popsize number of samples by default returned by ask ()
Method stop return the termination status as dictionary.
Method __init__ see class CMAEvolutionStrategy
Method ask get/sample new candidate solutions.
Method ask_geno get new candidate solutions in genotyp.
Method random_rescale_to_mahalanobis change x like for injection, all on genotypic level
Method get_mirror return pheno(self.mean - (geno(x) - self.mean)).
Method ask_and_eval sample number solutions and evaluate them on func.
Method get_selective_mirrors get mirror genotypic directions from worst solutions.
Method tell No summary
Method inject inject list of one or several genotypic solution(s).
Method result return a CMAEvolutionStrategyResult namedtuple.
Method result_pretty pretty print result.
Method repair_genotype make sure that solutions fit to the sample distribution.
Method manage_plateaus increase sigma by sigma_fac in case of a plateau.
Method condition_number condition number of the statistical-model sampler.
Method alleviate_conditioning_in_coordinates pass scaling from C to sigma_vec.
Method alleviate_conditioning pass conditioning of C to linear transformation in self.gp.
Method feed_for_resume Resume a run using the solution history.
Method mahalanobis_norm return Mahalanobis norm based on the current sample distribution.
Method isotropic_mean_shift normalized last mean shift, under random selection N(0,I)
Method disp_annotation print annotation line for disp ()
Method disp print current state variables in a single-line.
Method plot plot current state variables using matplotlib.
Method _set_x0 Assign self.x0 from argument x0.
Method _random_rescaling_factor_to_mahalanobis_size self.mean + self._random_rescaling_factor_to_mahalanobis_size(y) * y is guarantied to appear like from the sample distribution.
Method _prepare_injection_directions provide genotypic directions for TPA and selective mirroring, with no specific length normalization, to be used in the coming iteration.
Method _updateBDfromSM helper function for a smooth transition to sampling classes.
@property
def popsize(self):
def stop(self, check=True, ignore_list=()):
With check==False, the termination conditions are not checked and the status might not reflect the current situation. stop().clear() removes the currently active termination conditions.
As a convenience feature, keywords in ignore_list are removed from the conditions.
def __init__(self, x0, sigma0, inopts=None):
def _set_x0(self, x0):
Input x0 may be a callable or a string (deprecated) or a list or numpy.ndarray of the desired length.
Below an artificial example is given, where calling x0 delivers in the first two calls dimension * [5] and in succeeding calls``dimension * [0.01]``. Only the initial value of 0.01 solves the Rastrigin function:
>>> import cma
>>> class X0:
...     def __init__(self, dimension):
...         self.irun = 0
...         self.dimension = dimension
...     def __call__(self):
...         self.irun += 1
...         return (self.dimension * [5] if self.irun < 3
...                 else self.dimension * [0.01])
>>> xopt, es = cma.fmin2(cma.ff.rastrigin, X0(3), 0.01,
...                      {'verbose':-9}, restarts=1)
>>> assert es.result.fbest > 1e-5
...                      {'verbose':-9}, restarts=2)
>>> assert es.result.fbest < 1e-5  # third run succeeds due to x0
def ask(self, number=None, xmean=None, sigma_fac=1, gradf=None, args=()):
Solutions are sampled from a multi-variate normal distribution and transformed to f-representation (phenotype) to be evaluated.
Arguments
number
number of returned solutions, by default the population size popsize (AKA lambda).
xmean
distribution mean, phenotyp?
sigma_fac
multiplier for internal sample width (standard deviation)
gradf
gradient, len(gradf(x)) == len(x), if gradf is not None the third solution in the returned list is "sampled" in supposedly Newton direction np.dot(C, gradf(xmean, *args)).
args
additional arguments passed to gradf
Return
A list of N-dimensional candidate solutions to be evaluated
Example
>>> import cma
>>> es = cma.CMAEvolutionStrategy([0,0,0,0], 0.3)  #doctest: +ELLIPSIS
(4_w,...
>>> while not es.stop() and es.best.f > 1e-6:
...     fit = [cma.ff.rosen(x) for x in X]  # call fct with each solution
...     es.tell(X, fit)  # feed values
See Alsoask_and_eval, ask_geno, tell
def ask_geno(self, number=None, xmean=None, sigma_fac=1):
Solutions are sampled from a multi-variate normal distribution.
Arguments are
number
xmean
distribution mean
sigma_fac
ask_geno returns a list of N-dimensional candidate solutions in genotyp representation and is called by ask.
Details: updates the sample distribution if needed and might change the geno-pheno transformation during this update.
See Alsoask, ask_and_eval
def random_rescale_to_mahalanobis(self, x):
def _random_rescaling_factor_to_mahalanobis_size(self, y):
def get_mirror(self, x, preserve_length=False):
>>> import numpy as np, cma
>>> es = cma.CMAEvolutionStrategy(np.random.randn(3), 1)  #doctest: +ELLIPSIS
(3_w,...
>>> x = np.random.randn(3)
>>> assert cma.utilities.math.Mh.vequals_approximately(es.mean - (x - es.mean), es.get_mirror(x, preserve_length=True))
>>> x = es.ask(1)[0]
>>> vals = (es.get_mirror(x) - es.mean) / (x - es.mean)
>>> assert cma.utilities.math.Mh.equals_approximately(sum(vals), len(vals) * vals[0])
TODO: this implementation is yet experimental.
TODO: this implementation includes geno-pheno transformation, however in general GP-transformation should be separated from specific code.
Selectively mirrored sampling improves to a moderate extend but overadditively with active CMA for quite understandable reasons.
Optimal number of mirrors are suprisingly small: 1,2,3 for maxlam=7,13,20 where 3,6,10 are the respective maximal possible mirrors that must be clearly suboptimal.
def ask_and_eval(self, func, args=(), gradf=None, number=None, xmean=None, sigma_fac=1, evaluations=1, aggregation=np.median, kappa=1, parallel_mode=False):
Each solution s is resampled until self.is_feasible(s, func(s)) is True.
Arguments
func:
objective function, func(x) accepts a numpy.ndarray and returns a scalar if not parallel_mode. Else returns a list of scalars from a list of numpy.ndarray.
args:
additional parameters for func
gradf:
gradient of objective function, g = gradf(x, *args) must satisfy len(g) == len(x)
number:
number of solutions to be sampled, by default population size popsize (AKA lambda)
xmean:
mean for sampling the solutions, by default self.mean.
sigma_fac:
multiplier for sampling width, standard deviation, for example to get a small perturbation of solution xmean
evaluations:
number of evaluations for each sampled solution
aggregation:
function that aggregates evaluations values to as single value.
kappa:
multiplier used for the evaluation of the solutions, in that func(m + kappa*(x - m)) is the f-value for x.
Return
(X, fit), where
  • X: list of solutions
  • fit: list of respective function values
While not self.is_feasible(x, func(x)) new solutions are sampled. By default self.is_feasible == cma.feasible == lambda x, f: f not in (None, np.NaN). The argument to func can be freely modified within func.
Depending on the CMA_mirrors option, some solutions are not sampled independently but as mirrors of other bad solutions. This is a simple derandomization that can save 10-30% of the evaluations in particular with small populations, for example on the cigar function.
Example
>>> import cma
>>> x0, sigma0 = 8 * [10], 1  # 8-D
>>> es = cma.CMAEvolutionStrategy(x0, sigma0)  #doctest: +ELLIPSIS
(5_w,...
...     X, fit = es.ask_and_eval(cma.ff.elli)  # handles NaN with resampling
...     es.tell(X, fit)  # pass on fitness values
...     es.disp(20) # print every 20-th iteration  #doctest: +ELLIPSIS
Iterat #Fevals...
>>> print('terminated on ' + str(es.stop()))  #doctest: +ELLIPSIS
terminated on ...
A single iteration step can be expressed in one line, such that an entire optimization after initialization becomes:
    es.tell(*es.ask_and_eval(cma.ff.elli))
def _prepare_injection_directions(self):
Details: This method is called in the end of tell. The result is assigned to self.pop_injection_directions and used in ask_geno.
def get_selective_mirrors(self, number=None):
Details:
To be called after the mean has been updated.
Takes the last number=sp.lam_mirr entries in the self.pop[self.fit.idx] as solutions to be mirrored.
Do not take a mirror if it is suspected to stem from a previous mirror in order to not go endlessly back and forth.
def tell(self, solutions, function_values, check_points=None, copy=False):
pass objective function values to prepare for next iteration. This core procedure of the CMA-ES algorithm updates all state variables, in particular the two evolution paths, the distribution mean, the covariance matrix and a step-size.
Arguments
solutions
list or array of candidate solution points (of type numpy.ndarray), most presumably before delivered by method ask() or ask_and_eval().
function_values
list or array of objective function values corresponding to the respective points. Beside for termination decisions, only the ranking of values in function_values is used.
check_points
If check_points is None, only solutions that are not generated by ask() are possibly clipped (recommended). False does not clip any solution (not recommended). If True, clips solutions that realize long steps (i.e. also those that are unlikely to be generated with ask()). check_points can be a list of indices to be checked in solutions.
copy
solutions can be modified in this routine, if copy is False
tell() updates the parameters of the multivariate normal search distribution, namely covariance matrix and step-size and updates also the attributes countiter and countevals. To check the points for consistency is quadratic in the dimension (like sampling points).
Bugs
The effect of changing the solutions delivered by ask() depends on whether boundary handling is applied. With boundary handling, modifications are disregarded. This is necessary to apply the default boundary handling that uses unrepaired solutions but might change in future.
Example
>>> import cma
>>> func = cma.ff.sphere  # choose objective function
>>> es = cma.CMAEvolutionStrategy(np.random.rand(2) / 3, 1.5)
... # doctest:+ELLIPSIS
(3_...
...    X = es.ask()
...    es.tell(X, [func(x) for x in X])
>>> es.result  # result is a `namedtuple` # doctest:+ELLIPSIS
CMAEvolutionStrategyResult(xbest=array([...
See Alsoclass CMAEvolutionStrategy, ask, ask_and_eval, fmin
def inject(self, solutions, force=None):
Unless force is True, the solutions are used as direction relative to the distribution mean to compute a new candidate solution returned in method ask_geno which in turn is used in method ask. inject is to be called before ask or after tell and can be called repeatedly.
>>> import cma
>>> es = cma.CMAEvolutionStrategy(4 * [1], 2)  #doctest: +ELLIPSIS
(4_w,...
...     es.inject([4 * [0.0]])
...     X = es.ask()
...     if es.countiter == 0:
...         assert X[0][0] == X[0][1]  # injected sol. is on the diagonal
@property
def result(self):
See Alsocma.evolution_strategy.CMAEvolutionStrategyResult or try help(...result) on the result property of an CMAEvolutionStrategy instance or on the CMAEvolutionStrategyResult instance itself.
def result_pretty(self, number_of_runs=0, time_str=None, fbestever=None):
Returns result of self.
def repair_genotype(self, x, copy_if_changed=False):
This interface is versatile and likely to change.
In particular the frequency of x - self.mean being long in Mahalanobis distance is limited, currently clipping at N**0.5 + 2 * N / (N + 2) is implemented.
def manage_plateaus(self, sigma_fac=1.5, sample_fraction=0.5):
A plateau is assumed to be present if the best sample and popsize * sample_fraction-th best sample have the same fitness.
Example:
>>> import cma
>>> def f(X):
...     return (len(X) - 1) * [1] + [2]
>>> es = cma.CMAEvolutionStrategy(4 * [0], 1)  #doctest: +ELLIPSIS
(4_w,...
...     X = es.ask()
...     es.tell(X, f(X))
...     es.logger.add()
...     es.manage_plateaus()
>>> assert es.sigma > 1.5**5
@property
def condition_number(self):
Details: neither encoding/decoding from sigma_vec-scaling nor gp-transformation are taken into account for this computation.
def alleviate_conditioning_in_coordinates(self, condition=100000000.0):
As a result, C is a correlation matrix, i.e., all diagonal entries of C are 1.
def alleviate_conditioning(self, condition=1000000000000.0):
Argument condition defines the limit condition number above which the action is taken.
Details: the action applies only if self.gp.isidentity. Then, the covariance matrix C is set (back) to identity and a respective linear transformation is "added" to self.gp.
def _updateBDfromSM(self, sm_=None):
By now all tests run through without this method in effect. Gradient injection and noeffectaxis however rely on the non-documented attributes B and D in the sampler.
def feed_for_resume(self, X, function_values):
CAVEAT: this hasn't been thoroughly tested or in intensive use.
Given all "previous" candidate solutions and their respective function values, the state of a CMAEvolutionStrategy object can be reconstructed from this history. This is the purpose of function feed_for_resume.
Arguments
X:
(all) solution points in chronological order, phenotypic representation. The number of points must be a multiple of popsize.
function_values:
respective objective function values
feed_for_resume can be called repeatedly with only parts of the history. The part must have the length of a multiple of the population size. feed_for_resume feeds the history in popsize-chunks into tell. The state of the random number generator might not be reconstructed, but this would be only relevant for the future.
Example
import cma
# prepare
(x0, sigma0) = ... # initial values from previous trial
X = ... # list of generated solutions from a previous trial
f = ... # respective list of f-values
# resume
es.feed_for_resume(X, f)
# continue with func as objective function
    X = es.ask()
Credits to Dirk Bueche and Fabrice Marchal for the feeding idea.
See Alsoclass CMAEvolutionStrategy for a simple dump/load to resume.
def mahalanobis_norm(self, dx):
The norm is based on Covariance matrix C times sigma**2, and includes sigma_vec. The expected Mahalanobis distance to the sample mean is about sqrt(dimension).
Argument
A genotype difference dx.
Example
>>> import cma, numpy
>>> es = cma.CMAEvolutionStrategy(numpy.ones(10), 1)  #doctest: +ELLIPSIS
(5_w,...
>>> xx = numpy.random.randn(2, 10)
>>> d = es.mahalanobis_norm(es.gp.geno(xx[0]-xx[1]))
d is the distance "in" the true sample distribution, sampled points have a typical distance of sqrt(2*es.N), where es.N is the dimension, and an expected distance of close to sqrt(N) to the sample mean. In the example, d is the Euclidean distance, because C = I and sigma = 1.
@property
def isotropic_mean_shift(self):
distributed.
Caveat: while it is finite and close to sqrt(n) under random selection, the length of the normalized mean shift under systematic selection (e.g. on a linear function) tends to infinity for mueff -> infty. Hence it must be used with great care for large mueff.
def disp_annotation(self):
def disp(self, modulo=None):
Prints only if iteration_counter % modulo == 0.
See Alsodisp_annotation.
def plot(self):
Details: calls self.logger.plot.
API Documentation for cma, generated by pydoctor at 2019-04-24 23:06:54.
